Rod Bearings #'s 2 and 6.... Better Check Them All
Former Sponsor
Interestingly enough, the oil pan had a GTS baffle installed, which almost has to mean that someone has been in here, before. The oil pan has the correct date (40/89) date cast in to it, so it is doubtful it ever got replaced.
Man of many SIGs
We have built up line sets that allow us to use both a cooler in the radiator and the original cooler. Note that this also requires a change in the radiator, to get an oil cooler in the left tank.
This modification allows the oil to be cooled in traffic, by the radiator, and still allows heat to escape (when the car is moving) from the stock cooler. An interesting side effect is that this also allows the oil temperatures to warm-up quicker in cold weather, which further reduces engine wear. This is the best of all worlds and virtually all of these cars need to be modified.
BTW....Carl, no doubt, will steal this idea in about 2 minutes and then claim that he had no idea we were doing this and it was totally his idea.
Former Sponsor
These bearings simply ran out of oil film and were scraping on the crank.
Rennlist Site Sponsor
I will cheerfully state up front that my expertise is an order of magnitude lower than Greg's, but I am slightly puzzled by the uneven wear patterns. My first suspicion would be that the rod surface wasn't as clean as it should have been, but that is hard to accept on a factory installation.
I just think that contact wear from a perfect crank surface should be more even than that...
Former Sponsor
One thought...seems like all the bearings have the same wear, which would mean that they all have the same problem, with regards to whatever touches the crank, first.
Former Sponsor
The bearings are supplied by Porsche in three separate dimension "groups", which vary by about .0002, from size to size. These sizes are blue, yellow, and red...with blue being the "smallest/tightest" bearing. Porsche originally picked rod bearings that were sized to the particular crank...to get the correct oil clearance. The cranks were marked, when they were made with a paint mark and the assembler simply matched up colors. The colors washed off instantly.
Porsche r eplacement bearings are supplied two to a box and they are also marked with a color code, although you can not specify which color you want, any longer. They will always come with two yellows (mid size clearance), or one blue mixed with one red (tightest bearing with biggest bearing...I guess they think this equals two yellows?) You will see no other variations, unless someone has mixed things up, after they were boxed. We go through these bearings, confirm their sizes, and will actually pick sizes to get optimum oil clearance. (We would never put a blue with a red...makes no sense.)
The aftermarket replacement bearings, made by Glyco, don't come supplied with any colors. They generally come very tight. I think they plan on the cranks wearing slightly and intentionally build the bearings tight to compensate for any wear. However, the cranks are very hard and do not seem to wear...so it is very possible to get bearings that are too tight and not provide enough bearing clearance. Many engines have failed, immediately after a bearing change...possibly from this.
There is also some that think the bearings are constructed differently, of which I was one of. However, after weighing many of these bearings to try and compare, they all seem to weigh very very close to each other...which might indicate they are built from the same materials. I simply don't know.
I am currently running a test engine that has a "mixture" of factory rod bearings and Glyco aftermarket bearings, for a study. They were carefully selected to be all sized the same. We will run this engine for 6 months or a year and check the bearings for wear and compare them. There are also several other "developmental" pieces that we will be reviewing, when that "inspection" occurs.
Here's my ideas....measure very carefully and make sure that you have adequate rod bearing clearance. Compare the replacement bearings with the original bearings, for size purposes.
You've got to take this all with a grain of salt, however....I'm not an SAE member....so that magazine has not made me an expert.
So is plastigauge sufficient for checking the bearing clearances ? Do you replace the rod Bolts and or nuts ?
tho i have little experence with porshe (none to be fair) i have rebuilt many chevy and mopar engines and more often than not there is what looks like damage from , sand or some debrie on the rod bearings and yet the mains look fine, could someone explain or is it bad karma?Ray
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Former Sponsor
tho i have little experence with porshe (none to be fair) i have rebuilt many chevy and mopar engines and more often than not there is what looks like damage from , sand or some debrie on the rod bearings and yet the mains look fine, could someone explain or is it bad karma?Ray![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Former Sponsor
Always replace the rod nuts. Bolts should last the life of the engine, as long as they don't get overtightened. If you ever need to replace a bolt, the rod will need to be reconditioned (rebuilt).
