928 Forum 1978-1995
Sponsored by: 928 Specialists
MSD 6-BTM
Old Sep 13, 2010 | 10:00 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Default MSD 6-BTM
Anyone ever figured out how to hook one of these up to a boosted 928? I remember years ago, well before the shark tuner, some tired with limited sucess.
I have two of them collecting dust in my garage and figured it won't hurt to ask. One is red and the other is blue, made for Vortech.
File Type: jpg
Old Sep 13, 2010 | 11:18 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
I had one on my 81 last year. A bit more of a challange with dual distributors.
Old Sep 13, 2010 | 11:28 PM
danglerb's Avatar
danglerb
I think they work best when left in the box gathering dust.
Old Sep 14, 2010 | 12:58 AM
Speedtoys's Avatar
Speedtoys
Originally Posted by Imo000
Anone ever figured out how to hook one of these up to a boosted 928? I remember years ago, well before the shark tuner, some tired with limited sucess.
MSD? Get three of em...install two just to make sure you make it to work and back, and third because #2 fails soon after #1, before the replacement gets to you from Jegs/summit/etc.
Personal experience..never again.
Old Sep 14, 2010 | 02:07 AM
beentherebaby's Avatar
beentherebaby
In my experience MSD, aka Autotronics sells reliable ignition components. If you're having multiple unit failures then I'd suggest their might be an application issue that needs investigation not multiple defective MSD components?
As a side note... The MSD ignition was originally developed by Autotronics for Chrysler Corp. for use on their Hemi Drag Cars to eliminate sparkplug fouling from the rich AFRs they had to run back in the 70"s with carbs. FWIW, I've used MSD units on many applications without every experiencing a single failure. YMMV.
Old Sep 14, 2010 | 02:32 AM
Speedtoys's Avatar
Speedtoys
Aint much to installing one right...and I refuse to let my race car beat me..and well, I stopped using the MSD ignition boxes years ago (except the replacement to the OptiSpark on GM Fbods)..and ive not lost an igition system since.
Maybe its the vibration of the larger race cars, maybe it was the rapid fire of the rotaries..but..just sayin, you shouldnt -have- to run 2 ignition systems on a car to finish a race.
Old Sep 14, 2010 | 11:00 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
But it is on the dual coil 32V engines. I had the original box on my boosted Tran Am for 5 years and had no issues. It's not going on a race car so the environment will be less punishing.
Old Sep 14, 2010 | 11:08 AM
hacker-pschorr
Administrator
The stock dual coil setup has been proven to work past 600rwhp.
If you are having ignition problems, I say fix that before tossing an MSD box into the mix.
Beyond that, I see no reason why you cannot trigger the MSD box off the ignition modules down in the nose.
