cold engine - exhaust backfire
Chronic Tool Dropper
Symptoms say intake air leak to me.
As a quick check of the wiring I disconnected the temp II sensor............no start.
Re-connected the temp II and she fires right up so confirms the LH/EZK are getting the temp II signal.
I did make my own version of Dwaynes intake leak tool
............I'll try that out later today.
Perhaps John..............I did rebuild the intake a few years ago with all new gaskets, hoses, refurb injectors but used the old ISV (it tested good) and didn't replace the throttle shaft or flappy shaft brgs. The intake r&r, if thats what is required, will be a winter project as winter is quickly approaching here.
................and the winner is?
Intake leak!
With the engine running at idle I sprayed (perhaps to liberaly) brake cleaner around both sides of the intake/fuel injectors.............instant clouds of smoke from the tailpipe. I've no idea exactly where but I'll tear it apart when the snow flies.
Until then I'll live with the issue................thx for everyones input
Intake leak!
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Could be Colin.............they were new when I had the injectors cleaned but dont know the origin.
When I pull the intake I'll decide on new FIs and new ISV etc etc...........thx for the comments and the call
No worries,
I hope that there is a chance you might be able to make it down here.
If you do decide to come down let me know in advance and I can have an intake powdercoated and ready for a swap.
Under the Lift
It's possible to "catch" an injector o-ring on the lip of the hole in the manifold and not seal. I've done it. But I'm not sure why your issue seems to clear up after a couple of minutes.
That's my story and I'm, stickin' to it.
