MAF and fuel pressure problems
I am reinstalling the MAF. The engine is in the car (obviously). What is the best orientation of the clamp holding the bottom (downstream) end of the MAF in the boot that holds it to the throttle body? By best I mean an orientation in which I can tighten the clamp around the boot with minimum tear down?
On my S4 I have the clamp screw pointed toward the right side. It is easily accessible by removing the right fuel rail cover, unplugging the Knock Sensor connector and inserting a 1/4" drive socket on a long extension through the gap between the intake runners.
YMMV
Mike
YMMV
Mike
clamp pointing to the passenger side, long 1/4 extension, universal socket. no need to remove the knock sensor connector if you get the clamp orientation just right.
Thanks. Got it done. The clam screw towards the front of the car, with the socket end pointing towards the passenger side. Then a very long screw driver thru the hole in the fuel rail cover. I assume the fuel rail cover has a hole in it just for this reason. Two cuts and blood on the MAF on the outside, the JDS sticker has brown blood stains on it now.
Germans are such clever people that in the next world war I want to be on their opposite side. They always lose, and I can then hunt down the offspring of the engineer who designed this MAF clamp. (Also, if your ancestors were involved in designing that 12-point XZN socket, keep watching over your shoulder...)
Yes, we Germans like "über"engineered solutions! ;-)
But we do it on every car in a product batch the same.
Old British car assembler put in every car a different electrical system.
And it´s a fact, Lucas is the inventor of electrical darkness!
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Are you using a stock MAF boot? If so, are you aware of this?
https://rennlist.com/forums/928-foru...take-hose.html
going up to 15 psi max boost. It stays on better then the stock boot and
clamps, but I have been able to blow it off if I don't tighten the heck out of
the T-clamps. Using an 11 mm socket allows me to get more torque on the
bolt then a screw driver.
Are you using a stock MAF boot? If so, are you aware of this? https://rennlist.com/forums/928-foru...take-hose.html
(The British car manufacturers are excluded from this ranking because I don't think they ever got their production volumes up to more than one car per day. Their cars required so much custom carpentry, I think...)
I'm still using that MAF Boot. It's held up well so far. Of course I'm only going up to 15 psi max boost. It stays on better then the stock boot and clamps, but I have been able to blow it off if I don't tighten the heck out of the T-clamps. Using an 11 mm socket allows me to get more torque on the bolt then a screw driver.
I am no engineer, but it seems that for just the clamping force to hold the boot in place with no lip or other such contraption would require some serious clamping force.
My screwdriver was long enough, but I had to pull out the provent, the air box, some cold-sdie piping, etc. to use it. A royal pain in the *** figuratively, and in the hand more literally since the various steel straps cut me many times. Death by thousand cuts, almost.
Harbor Freight… extra Long 1/4 inch 'wobble' extender... even easier to use than a universal swivel.
Great addition to any socket set:
http://www.harborfreight.com/9-piece...set-31203.html
Also, I clean the boot with Carb cleaner, then use a little more as a lube to get it on. When it evaporates completely, the rubber is really sticky.
Man of many SIGs
Tuomo, I had a similar issue with my car where the silicon boot would slip off the AFM. I tried putting grip tape around the outside of the AFM where the boot clamped on but it didn't last. I ended up taking an air grinder and a cut off wheel and scoring the area where the boot was to clamp. I didn't score it all the way around because I didn't wan't to introduce a failure point by doing it that way. Instead I just scored it intermtiantly three dashes one on top of the other then an inch of nothing, then three dashes then skip another inch etc. This has worked well for me so far.
Can you explain to me how that silicone boot works, especailly with a clamp that is not strapped to the MAF housing? The stock clamp system is apprently designed to work in a way that the steel straps locate the clamp relative to the MAF housing and the stock boot lip locates the clamp relative to the boot. There's no lip in the MAF housing and there's no lip on the silicone boot, so how does an strapped clamp hold it in place? Are you using fabricated straps on the clamp and does the clamp then sink into the silicone?
boot under high boost and temps. Both Tim M and Dave L had similar experiences
as I had with the stock boot "blowing out". The fact that the silicone boot can
use a wider stronger clamp and is more malleable allows it to have more force
applied to the clamp to hold it in place. The 11mm socket on a long wobbly extension
can be tightened a lot more then the small stock clamp without fear of tearing
the boot.
Stock boot from the 2008 Bonneville 100:
![](http://928.jorj7.com/2008-bonneville/images/0620-154912-01.jpg)
New stock boot from the 2008 Pony Express two months later:
![](http://928.jorj7.com/2008-pony/103/0830-142530-01.jpg)
