Pics of oil pan/cross-member: Do I need new MM's?
Basic Sponsor
The solid rubber MM's on the pre 83 cars do not collapse like the later style.
Does the engine rock side to side when you rev it?
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Never noticed it rocking, and it doesn't seem to be very close to the cross-member. They look fine, solid, formed, but I'm dying to figure out why so much heat continues to roll into the cabin through the shifter port, and somewhere else unknown. I've closed off the valve that lets hot water into the heater core. No change. Sprayed gobs of expanding foam up over the TT, helped a lot, but it seems to be returning to it's original state. It's very frustrating considering how bad this summer has been, and my A/C doesn't work. I cannot just not drive this car.
Tonight I noticed hot air coming through the door vents, even though I closed off the hot water valve to the heater core. Something else is going on here.
Now I've got warmed air coming through the door vents.
Team Owner
from your post you need to follow Wallys post about inspection of the HVAC system.
It sounds like you have one or more inop vacuum pods that are leaking this will let the HVAC system do what it wants.
Go to 928gt.com and on page 2 under tips and links find the thread about HVAC sytems
Will do, MrMerlin. Thanks.
