Block damage What would you do?"
#77
ic
Brad, you da man!
Take lots of pictures.
#78
Chronic Tool Dropper
Most important piece of equipment in that picture is undoubtedly the air conditioner.
#80
#83
#84
I am guilty of TIG welding with uncovered arms.
Luckily for me it was short duration (5 min or so), and I simply do NOT sun burn on my arms, neck or head.
Worked in the chihuahua desert for months with no shade, hat etc. and didnt burn at all. I did however become very dark....
#86
Almost Deleted
I wanted to update the thread with a bit of progress. Thanks to the efforts of Brad, Sean, John and Roger while I was out of town, the block was cleaned, patched and welded. The bad piece on the existing girdle was cut clean in order to make room for a piece from a spare girdle. Thanks to Roger, we had a spare girdle to cut a good corner piece, including the mounting points for both the AC unit and the alternator. Brad had everything jigged up in order to make sure things were square and the gasket surface was flush. Everything was welded while on the car.
Last night, we cleaned and pookied the welded areas as well as the rod bearings. A new silicone pan gasket and stud kit were installed with the existing pan and a new set of motor mounts[parts thanks to Roger at 928sRUS]. We also got the harmonic balancer, alternator, ac compressor and tb guards back on. Next step is to press in the new rack bushings and button up the bottom end.
Once we can set the engine back on the mounts, we'll put in a full change of oil, spin up the engine VERY briefly, then drain the oil and change the filter. We want to make sure and get out all the little aluminum chips. Needless to say, I'm smiling ear to ear!!!
Just a quick thanks to everyone involved in the repair so far... especially BradW!!
So.... pictures!!! If you're interested in all the pictures, they're posted here: http://www.renntube.com/view-album/21/s4-block-repair
#87
... Once we can set the engine back on the mounts, we'll put in a full change of oil, spin up the engine VERY briefly, then drain the oil and change the filter. We want to make sure and get out all the little aluminum chips. Needless to say, I'm smiling ear to ear!!! ...
I wonder if you could leave the pan off, plumb the pickup into a bucket of clean oil, spin it and let the return make a mess into a plastic sheet? Or even plumb a pump to the pickup and and pump a bunch of solvent/kerosene through the engine without spinning it? I guess the oil pump would act like a dam if you tried that. Pump it in through the oil filter mount?
#88
its only aluminum it wont hurt the gears in the pump the filter will grab all the bits i would run the engine leave the oil and change the filter in a day then dump the oil and filter in a couple days
