928 Forum 1978-1995
Sponsored by: 928 Specialists
Ride Height
Old Aug 2, 2010 | 11:25 PM
blown 87's Avatar
blown 87
Rest in Peace
Originally Posted by mark kibort
Doing alignment also changes ride height.
mk
Why, the changes should be very small unless the alignment was way out and i could not see it changing much if any.
Old Aug 2, 2010 | 11:59 PM
mark kibort's Avatar
mark kibort
Hey, if the ride height is way out, same thing. . The poster on the other thread was doing an alignment that was "Way out", as he was going from stock to near 3 degrees, right? of course he never got there, but all sorts of things would change on ride height with those kind of changes.
Both can move things around, a surprisingly amount. just dong my camber, changed the ride hight near 10mm in front. So, it depends.If your ride hight is close and so is your alignment, the small adjustments should be fine to make.
Old Aug 3, 2010 | 04:33 AM
Nightfly's Avatar
Nightfly
Reanimator
Many of the "old timers" on this list may recognize the "YMMV" comment - it originated with Ed Ruiz.
That phrase came from a TV commercial back in the sixties, if not before, and was often seen on usenet posts as well way before Rennlist existed on the web. Was Ed Ruiz instrumental in those commercials?
