What is the best performance upgrades/dollar?
#31
Oh, don't forget about:
http://www.sharkwerks.com/main.php
Oh that's right, they don't sell anything 928 related... hense the name.
Dollar for dollar would have to be x-pipe at about 7.5% rate of return (HP/$)
#32
Under the Lift
For CA keep your car stock or you will have trouble with smog. The smog shops are getting more and more strict about checking for headers and non-factory cats, etc.
Er, uh, do as I say not as I do.
#33
Norcal
I am looking at Northern California to move as a Teacher. That is if they have any jobs there when I finish my Masters next spring. If not, I will look at moving back up to Seattle. The heat in AZ is killing me in the summer.
#34
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Bill is right. This would be the route to go preferrably. If you wish to still to an X-pipe, purchase one that can be swapped out on your smog days and keep your OE cats some place safe where they cannot be damaged.
#37
Brett went from stock 15's to 13seconds with alittle over 200hp I would think a later model car would go from higher
14's to mid 12's in the 1/4 mile with the same setup.
#42
Agreed. New spark plugs will probably be worth at least several HP and offers the best Increase/dollar spent. Unfortunately this is not a permanent gain.
#43
First find out what you have NOW.....take it to a dynojet and do a few runs. That way you KNOW what you are starting with and can measure what if any gains you get. At this point you do not even know if the camshafts are properly timed or what the belt looks like and if the belt warning system still works.
#44
Some folks have done custom crossovers.
#45
