Oil Pressure Gauge
Team Owner
turning on the key made the gauge peg, this was without starting the engine
Perhaps I can re-phrase my query:
- when the motor was running did the gauge exhibit any strange behaviour
- when you stopped the motor did the gauge return to the pegged condition? I suspect not the case.
Still having issues myself as per the thread I initiated. Starting to suspect my "new" sender may be duff.
Team Owner
Fred, once the key was turned to run or crank the gauge would peg and stay pegged till the key was turned off it did not matter if the engine was running or stopped it was pegged
At my wits end with it.
