Mark, since you aren't running a modified fuel chip and you haven't shark tuned, how are you increasing your inj. pulse durations? And how do you know they are at 95%?
The Data logger indicates they are pegged, after this test I think I may have received the wrong ratio Fmu when I purchased the kit.
As you know I have been chasing this lean and stumbling issue since I installed the S/C kit.
For now I am waiting on Tim for his feedback, I sent an E-mail a few days ago about the chips and Afpr and this thread took me down a different road.
SUPER FUEL MANAGEMENT UNIT (SFMU)
The Super Fuel Management Unit has all of the features of the Fuel Management Unit and also features 5 separate adjustments that can be used to ''shape'' the fuel pressure curve. These 5 adjustments are:
The main spring adjusting screw
The calibration ring & disc
The vacuum screw
The optional bleed screw
The boost screw
I am going to install the adjustable fuel pressure regulator today. I need to remove my piping Etc any mods need to be done on the fuel lines, since its buried I would like to know if I need to chop or add new hose to it.
