printed circuit
i have been trying to find a printed circuit for my 1978 928 with out any luck can any one help even with good working used one i also need the plugs from the car wiring to the printed circuit my wiring look like this at present if you have a picture that show the wiring order that will be great help//////
I have been doing some research on circuit foils.
The part number for 78 was 928 641 923 00 which is no longer available.
However PET 7 says this is used on 78 to 82 cars.
The next circuit foil in PET for up to 81 cars is 928 641 939 00 which is available and I even have two in stock. My gut tells me that they probably are backward compatible.
I sell the 928 641 939 00 for $95.
If I am right this is great news for the early 78 cars.
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
George Layton March 2014928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."
How many connectors are there on your instrument cluster, 2 or 3? They should be 12 pin connectors. The 80's and above have three connectors and the 78-79 have two. [i believe signaling the delta between CIS and L-Jet]. The 83's went to 14 pin connectors.
I have both the 78 - 928 641 923 00 and the later 928 641 939 00 here and they are identical with two connector tabs on the bottom.
Happy to supply the 928 641 939 00 and if it does not work refund the money.
hi pls send me a picture of the foil and an paypal request if all ok do you have the plugs as well for the connectors i need all 3 ther 2 under and one on the side in the middle of the printed foil i need the 78 one if you got it so send me a picture i can tell if it is the right one thanks rog
