928 Forum 1978-1995
Sponsored by: 928 Specialists
New Product: High-Performance Intake Runners for the 32v 928
Old 09-05-2010, 07:26 AM
  #76
928mac
928mac's Avatar
Thanks for sharing Carl, very very nice work
928mac is offline
Old 09-05-2010, 05:29 PM
  #77
Carl Fausett
Developer
Carl Fausett's Avatar
Thanks, guys. Can't wait to track a 850 HP 928 - should be a handful! :-)
Carl Fausett is offline
Old 05-11-2013, 10:27 AM
  #78
ptuomov
ptuomov's Avatar
Originally Posted by Carl Fausett
The finished intake runners were flow-bench tested as were the original Porsche 32v intake manifold runners. We checked all the runners in the OEM intake manifold and found cylinder #7 to be the most typical, and based our measurements there. Measurements were conducted in such a way as to isolate the runner design only, and remove the plenums from consideration. The stock intake runners flowed 244.75 CFM.
Do you have the individual runner CFM numbers for the stock S4 manifold with and without the plenum covers on?
ptuomov is offline
Old 05-13-2013, 12:48 PM
  #79
Carl Fausett
Developer
Our measurements were of runner #7, and we were only interested in the runner (not the manifold) CFM measurement, so the side cover was off. The stock intake runner flowed 244.75 CFM.
Old 05-13-2013, 02:02 PM
  #80
mark kibort
mark kibort's Avatar
wow! impressive!
NOW where iis the NA version???
the runners are the hardest part, and thats done. Good, now make a single plennum and just use a larger TB and the stock MAF and feed it to the rear or front of the engine. just keep it real simple.
someday, this will be a reality! But when!!????
Mk
mark kibort is offline
Old 05-13-2013, 02:43 PM
  #81
Carl Fausett
Developer
Mark, this was first posted 7/29/2010.
It's been available every since.
I am not going to make the top end.... too many different ways that could go: single plenum, dual-plane plenum, ITB's, boosted, etc. So I just designed the runners with o-ring seals on top and let the end user make the manifold or throttle body system they want.
But you're right, the hard part is done for you!
Quick Reply: New Product: High-Performance Intake Runners for the 32v 928
