central electric panel
Hello from new928 owner. model 928s 1983. Just wondering if there is any way to disable the central warning panel. As far as i'm concerned it is just an annoyence to have it kick in for just about no reason at all. Right now it's showing brake pressure light but the brakes have been refurbed and flushed etc' and it's just driveing me nuts! reset button doesn't turn it off! By he way both pressure switches on the master have been replaced along with booster and pads.HELP PLEASE!!
Hi and welcome. You might want to change the title to brake pressure warning or similar. You don't want to disable the warning lights because it's annoying. It is supposed to be annoying. Somebody with knowledge of MY 1983 and brake pressure warnings will chime in soon.
There's a warning when a brake circuit fails. I think the warning is triggered by uneven pressure between the two pressure switches on the master cylinder.
Rennlist Site Sponsor
Up thru 1983, the brake lights are operated by twin pressure switches on the bottom of the brake master cylinder. From 1984 - up, the brake lights are operated by a simple plunger switch mounted on the brake pedal under the dash.
The earlier brake light switches do double-duty, operating both the brake lights and the brake pressure warning signal. These switches can cause some problems.
The switches are identical - one in each hydraulic circuit. They are single-pole, double-throw switches. This means that you have only one circuit (single pole) thru each switch, and that the switch chooses one of two outputs (double throw).
Each switch has three connections: power, central warning computer, and brake light.
Not Activated
There is a power feed into each switch. When the switch is not activated (no pressure in the brake circuit) the power isn't hooked to anything.
When the switch is not activated, the central warning computer and the brake lights are connected inside the switch. Nothing happens, since there is no power applied on either circuit.
Activated
When the switch is activated by brake hydraulic pressure in one of the circuits, the central warning computer connection is broken, and the brake lights are hooked to the power feed. This removes the central warning computer from the circuit, and puts power on the brake lights.
(This might be easier to visualize if you think of three wires: one for 12 vdc, one to the brake lights and one to the warning computer. The lead that goes to the brake lights is connected to the one to the warning computer until brake pressure pushes it off of that wire and over to the one going to power.)
All three leads go to both switches.
When you apply the brakes, both switches should activate. Both switches disconnect the warning computer and connect the power to the brake lights. The brake lights come on, and no signal is sent to the warning computer, so it is happy.
If only one switch activates (either no pressure on one side of the brakes, or a bad switch), then things change.
On the switch that is not activated, the brake light circuit is still hooked to the warning computer.
On the switch that activates, the brake light circuit is hooked to 12 vdc.
The brake lights come on.
In addition, power flows on the brake light circuit back to the non-activated switch. Since in this switch the brake light circuit and warning computer are hooked together, 12 vdc is applied to the warning computer circuit. This sets the Brake Pressure Warning light.
Not Activated
Activated
