Some suspension plans for you to tear apart
No, thanks BC. I definitely don't want to move along without understanding at least a bit about this. I think this will get me on the right track, had not considered the difference between spring rates at the spring and at the wheel, which with hindsight is such an obvious thing.
Chronic Tool Dropper
Mike --
Do you happen to have the info at hand on what's the leverage ratio for the front and rear? Does the rear suspension also have a similar leverage ratio?
Also, if I just look at the geometry of the setup, is it enough to assume that the tire midpoint is the contact point and then just compute the leverage ratios from the angles and the part lengths?
Best, Tuomo
Best, Tuomo
The lever arms end at the bushings inner, and bushings outer rear, lower balljoints outer front. This is tape-measure math and a little trig for the shock angles. Rear is more fun with the multiple pivot points. Unless you are modeling all the travel, this stuff will be not so valuable. No matter what, a 300lb/in spring --at normal position-- will be half as stiff as a 600lb/in spring at the same position.
I'll definitely have to think about this much more before committing any cash.
My advice: if you drove one you liked, copy it. If you want a development project, read all the other advice here and bet your $$$.
I like my ext adjustable koni's with the 600/400 setup and adjustable perches.
Administrator - "Tyson"
Not to mention suspension and chassis setup is one of those black arts. Just because it "feels" faster, are you sure it's actually going around corners any better?
IMO the "butt dyno" is far more misleading when it comes to handling than HP mods.
This is a subject where someone like Mr.Simard is such a valuable asset, he "gets it" in a way I will never fully understand.
I'm going to stick with my stock sport shocks and upgrade the springs thanks to Mark A - then go with the 928 Specialists Sway Bar.
After that I'm not really sure. Maybe bug Mike Simard some more about copying his control arm bushings
I think you are on the right track, problem is you just might have to bite the bullit and do some trial and error.
That's the damping you feel as harsh.
What B' is talking about is the motion ratio unique to the 928 that has a spring giving a much lower wheel rate than the spring's rate. The wheel rate with the 600s is something under 200. It's a motion ratio way beyond other cars with arms and another world from strut cars and their 1:1 spring to wheel rate.
One of the aussie 928 owners has a GT with a custom setup of 1200lb front, 600lb rear hot-forged springs on it, and externally adjustable Koni's (can't remember if they're custom valved). He bought the car from an owner who had the setup worked out by a race shop for street/track use.
A bunch of the other 928 owners have driven it and all lust after his ride quality - firm, but not rough and doesn't jolt or rattle teeth even on our crap roads.
Some discussion on our local 928 mailling list about the wheel rate ratio (0.83^2 I think for the front?) and effective spring rates puts 1200lbs at around 830 effective.
That coupled with the fact that being hot-forged makes a difference too apparently?
We've kind of ignored the effects of anti-roll bars on net spring rate when cornering. If you do enough reinforcement to the frame brackets, a beefer (read: MUCH beefier) anti-roll bar will do a lot for apparent handling without doing so much to your fillings. Just do both ends of the car together so you don't end up in a wall one-end-first someplace. Carl's splined front torsion bar with the hard levers is a nice piece with a good bit of tunability. Anybody using that on a street car?
Based on one example I wouldn't go higher than 500 350 on street car. 600 400 with Leda shocks on SC'd S4 is too hard for local rods. It will come out and Bilstein/Eibach will go in later this year. Leda's will go to racecar build which will be road legal.
Rest in Peace
With the exception of very few here i am willing to bet that goes for most of us here.
i know very little about this stuff, so this thread is a great thing for me.
+1
I have leda's 800 front and 525 rear plus carls front anti roll bar and brackets on the rear, for me the car is perfect and not to stiff for our rubbish UK roads.
This set up has totaly transformed my car for me its not far off a large go kart
I find my 600/400 with adjustable Ledas quite stiff in a slightly lighter S body. Even turned right down with very little damping they are still stiff and you will crash into bumps. I agree with Errka and another aussie rennlister has that setup (500/350) with a GTS and says it is great. Earlier cars I would go with 400/250.
Greg
Greg
I am personally still skeptical of using a solid shock mount on an non-caged street car. I have to think there will be some pivoting forces in there somewhere, which is why I would think a jointed top-mount would be a better solution in this application, such as:
http://www.racersedge-inc.com/racers...open&id=11.4.1
Certainly not as affordable as the standard solid mounts, but may be an better strategy for the stock chassis.
I've been baffled by my own ignorance on this topic, so I order a couple of entry level books from amazon.com. Let's see if I can make any sense of this suspension stuff.
AFAIK all of the 944 camber plates use a spherical bushing, running those on the street is a very popular option.
There are a few threads discussing this in the 944 and 951 forums, here is a recent one:
https://rennlist.com/forums/944-turb...er-plates.html
One possible downside is lubrication, need to make sure that joint doesn't go dry. I doubt that is a PTFE lined bearing like Mike Simard uses with his bushings. If it were, kinda odd they don't mention it.
AFAIK all of the 944 camber plates use a solid bushing, running those on the street is a very popular option.
