928 Forum 1978-1995
Sponsored by: 928 Specialists
The 928 oil pump thread!
Old 06-22-2010 | 06:22 PM
Kevin Johnson's Avatar
Kevin Johnson
Default The 928 oil pump thread!
Anybody got some pics of the oil pumps used in different years/engines?
In case anyone is interested, the pump used has a very interesting heritage. I followed patents back about 70 years -- they discuss how the pump was intended to avoid cavitation problems and to dissolve gases/bubbles into the pumped medium.
I would think there are more but here's a few:
2424750
2774309
2983228
3204564
3785756
Old 06-22-2010 | 08:24 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Thanks a lot, now I have to run to the store.
I'm out of popcorn.
Old 06-22-2010 | 08:32 PM
Kevin Johnson
I'm out of popcorn.
I would like some Orville Redenbacher Kettle Corn please.
Old 06-22-2010 | 08:37 PM
hacker-pschorr
Administrator
We'll cook the corn in all the Mobil 1 Kibort is throwing out.
Old 06-22-2010 | 09:01 PM
Ducman82's Avatar
Ducman82
OOOO Carmel Corn! i have not been able to find that at the store anymore (make your self kind)
But i am wondering if there is a oil pump upgrade for better pressure and volume. im going to build up a 4.7 euro, so i will keep my eye on this post.
Old 06-22-2010 | 09:26 PM
IcemanG17's Avatar
IcemanG17
I prefer kettle corn
at some point the pumps were made wider for increased flow...but I am not sure when it happened?
Old 06-22-2010 | 10:26 PM
User 4221's Avatar
User 4221
Does the pump have a venturi? Also, does it resemble a turbo or supercharger? I'm sure the turbo version is much better
Old 06-22-2010 | 10:59 PM
GlenL's Avatar
GlenL
OK, funnyboys.
I've handled two variants ('80 and '84) and they're the same except for the shaft oiling.
Old 06-22-2010 | 11:16 PM
hacker-pschorr
Administrator
Just use the one that's right for your block, I made the mistake of installing the wrong one and I had a mess on my hands.
Old 06-23-2010 | 01:59 PM
Kevin Johnson
Originally Posted by GlenL
OK, funnyboys.
Ok, I have some pics of one with a shaft oiling drilling. This I very strongly believe to be a deaerator circuit.
The bearing clearance serves as the metered orifice. The triangular or trapeziodal opening at the bottom of the block/bed-plate recess dumps into the sump area next to the pickup.
Old 06-23-2010 | 02:03 PM
Kevin Johnson
Here are some pics of MK's 4V block. The dumping recess is still there in the bedplate and the pump housing appears to have the area that was drilled.
Is the drilled passage in the pump body and shaft bushing what has been deleted? Or is the dumping recess closed on some blocks or?
Old 06-24-2010 | 12:25 AM
Kevin Johnson
Now, on a more serious note.
What has always raised my ire is when certain academics attempt to control access to information and limit the free exchange of ideas. They do not want you to have access to the raw data but rather their processed or accepted interpretation of it. They want to be the gatekeepers.
The next level is when they attempt to derail members outside the club by throwing out assorted red herrings like definitions or knowledge of jargon.
Recently we were treated to an example of this when the discussion of the general design of the pump in the Porsche 928 was sidetracked by an attempt to argue over the definition of a gerotor pump.
M.F. Hill is generally acknowledged to be the father of the gerotor pump though assuredly there are many people prior to him who worked on the design.
In U.S. patent number 1682564, Hill makes some very enlightening remarks in the specifications area.
On page 4, lines 60-73, he writes [my emphasis]:
My new mechanical rotary movement comprises two rotors, a pinion rotor working inside and geared with an outer annular or ring rotor. The pinion preferably has one less tooth division than the annular, and all pinion teeth may be theoretically in contact with the annular contour at all times, and in practice in chambers that must be tight, with enough lost motion elsewhere to work freely.
The pinion is eccentric to the annular and together they open and close chambers between them as they rotate on eccentric axes.
The Porsche pinion gear has two less teeth. OH MY ! A mere "preference" does not a stricture make.
And on lines 126-130 of the same page:
I do not limit my invention to these dimensions for any rotor curves that have a sufficiently continuous co-acting relation with a good driving contact will answer.
The crescent element of the Porsche pump enables this.
And then on Page 7, lines 31-37, Hill writes:
Many variations may be made to my invention without departing from its spirit. Parts may be used along or in combination with one or more others. I claim all such novel features, shown or described, as lying within my invention, whether used singly or in various novel combinations.
Please, I encourage anyone remotely interested to read the full text of the patent and observe the images.
http://patft.uspto.gov/netacgi/nph-P...&RS=PN/1682564
I believe that it is very plain that the design of the pump in the 928 is in fact a member of the subset of gerotor pumps whose annular gears have greater than N+1 minimum teeth or lobes.
Old 06-24-2010 | 12:32 AM
Aloysius's Avatar
Aloysius
While i do find this interesting, don't patents expire after 20 years or so?
Old 06-24-2010 | 01:25 AM
hacker-pschorr
Administrator
Originally Posted by Kevin Johnson
In U.S. patent number....
Didn't we cover this already?
Originally Posted by SchmidtMotorWorks
If you know anything about patents, know this, they aren't reviewed for the validity of thier claims.
Old 06-24-2010 | 07:01 AM
Kevin Johnson
Yes, that is correct. Patents are extremely useful storehouses of information and are intended to be.
Reading a patent can often give you an insight into what the inventor was thinking about in contemporary terms as well as his or her vision of the subsequent developments in the field. Much more than these two points is possible though.
Quick Reply: The 928 oil pump thread!
