928 Forum 1978-1995
Sponsored by: 928 Specialists
Upper A-Arm
Old Jun 18, 2010 | 05:36 PM
rluvsporsche's Avatar
rluvsporsche
Default Upper A-Arm
I've search the forum but can find what I'm looking for.
Does anyone know the dimension on the studs the hold the front upper A-Arm?
Lenght, thread pitch and so on... Need to replace mine with a longer one 5/8" to be exact.
Thanks in advance.
Old Jun 18, 2010 | 06:22 PM
Leon Speed's Avatar
Leon Speed
Why?
It will not be easy though. It's not a simple bolt as you know. They're pressed thightly into the arm, you'll probably need to do some smithing.
Old Jun 18, 2010 | 06:37 PM
Mark Anderson's Avatar
Mark Anderson
The Parts Whisperer
I believe they are wheel studs
Old Jun 18, 2010 | 06:57 PM
rluvsporsche
Do you carry these longer in lengths?
Old Jun 18, 2010 | 07:07 PM
Mark Anderson
The Parts Whisperer
I do carry some that are 10mm longer.
Old Jun 18, 2010 | 07:12 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
Thanks in advance.
Fitting an early control arm to your later car?
Old Jun 18, 2010 | 10:11 PM
rluvsporsche
What's the total length?
Old Jun 18, 2010 | 11:39 PM
Mark Anderson
The Parts Whisperer
80mm
Old Jun 19, 2010 | 12:04 AM
Lizard928's Avatar
Lizard928
Yup, I swapped the stock pieces with bolts.
I used 70mm long, 10.9 grade hardware.
I also put the bolts through from the engine bay side.
Now I have the nuts in the fenderwell and can zap them off with an impact without having to touch the inside.
Old Jun 21, 2010 | 02:59 PM
rluvsporsche
80mm
How much? Do you know the exact size of the original?
Reason for asking I want to make sure I have enought threads to hold the bolt.
Old Jun 21, 2010 | 03:20 PM
Mark Anderson
The Parts Whisperer
The original's are 72mm and the 80mm are $15 ea.
