cold start stumbling
To the subject...............just ran the car 1300kms this weekend with warmer ambient temps and the intial start up idle is better...........less stumbling.
Concluding that ambient temp has effect........... question is do all temp II, water temp and air temp sensors affect cold (overnight) idle inputs?
Car is smooth after ~3mins of running and remains so.
Under the Lift
Air temp sensor has no effect on fuel mixture or ignition timing, just fan operation. Temp II could cause cold start/idle issues if it were reading incorrectly low resistance, but that is usually not the direction of failure. Temp II is the water temp sensor for the LH and EZK.
