WTB: driver window seal and door molding/gasket
I'm looking for USED condition driver window seal (not the actual door seal)....
It's the seal that fits INSIDE the upper door frame where the window seals when closed....
I also need the outside driver window rubber weatherstrip with the clips to mount on the inside of the door.
Take a look at the photo below for clarification on the 2 seals I need....Email me if you have anything in used but usable condition (not dry-ratted). Thanks
Team Owner
the outer window seal at the base isnt usually something you can get used as it work hardens and removing it from the donor car usually destroys it.
The upper seals are a different story, they can usually be used again
I'm hoping someone who's parting out a 928 can provide one or both of the seals as both of them are missing from my car.
