Need Help with Engine Wiring
Well the pace of my TB/WP/Throttle body has been lets say slow. I am starting to get things back together, but I ran into an issue, and I hope I can get some help.
The front wire harness that runs accross the TB cover has two pairs of wires that come out of the harness. Where do these pairs of wire go?
A/C compressor and the timing belt tension warning plug. (it's on the front cover by the dip stick)
Under the Lift
The engine harness that comes across the front of the motor does have the AC compressor clutch lead, and it also has the wire pairs for the water temp sensor (left side of water bridge) and the intake air temp sensor. The air temp sensor wires are the longer ones. The TB tension lead is not part of this harness but comes off the FI/Ignition harness. Here are pics of the complete harness and close-ups of the water temp and air temp wire ends.
![](http://www.norcal928.org/images/MikesParts/eharn01a.JPG)
![](http://www.norcal928.org/images/MikesParts/eharn08.JPG)
