Vacuum Jump to Heater valve.
Replaced one way vacuum check valve (kragens). 4-way connector (vacuum line spider) one leg fell off in my hand, pieced it together w/some splices and plugs. Seems that everything is working to turn off heat and turn on cold. Will try it out for a bit and then order the right replacement parts. But got the AC going so far for under $10.00, we will see how it goes.
