No Love, from either Window!
Went for a ride today 84MY, windows went down at the start of the ride, but would not roll back up at the end, driver and passenger. Fuse looks good, but swapped it with new one anyway, still no love.
I pulled the window winder relay, looks clean, but when I apply 12v to it I hear no click.
Would this relay if failed cause both windows to be in-op?
Also, should this relay click when 12v is applied?
This is relay #928.615.116.00.
Thanks for the help!!
Shawn
Shawn
happened to me last week, try your ignition switch. I gave mine a very slight turn counter clockwise and everything worked fine......looks like a new switch in near future for me.
Relay is where I would start. Both windows out at same time is a relay or fuse issue typically, and you already checked the fuse. Not likely an ignition switch issue, as other systems would be affected.
