Evaporator drain question
I tried search, I cant figure that function out.
Anyway,
I get a bath on my gas pedal foot from the ac now that it works.
where is the drain?
Anyway,
where is the drain?
Rennlist Site Sponsor
Goes thru the edge of the tunnel, pretty much above the exhaust. Hard to see or access...
If you poke something up the drain to clear it, make CERTAIN that is is not something that will punch a hole in the evaporator or heater core! $$$
On my 83 RHD car, its on the left side of the tunnel near the front - for a LHD, Not sure. From the sound of your complaint, I would guess its on the driver side, ie same place as mine - pull the driver side console side panel. Its just a rubber tube going through the body - sounds like its died, or it thinks your feet need a wash. Also, have you checked the heater air inlet drain flap on the firewall for debris? Oval flap ~ 1/2 way down .
jp 83 Euro S AT 52k.
