928 Forum 1978-1995
Sponsored by: 928 Specialists
Broken automatic transmission gear selector cable.
Old May 24, 2010 | 06:24 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Default Broken automatic transmission gear selector cable.
How common is this?
I cannot say I've seen many / any threads on this.
Other than age, any known culprits that cause this to happen?
Old May 24, 2010 | 07:16 PM
blown 87's Avatar
blown 87
Rest in Peace
Mine broke if that means any thing.
Old May 24, 2010 | 07:25 PM
SeanR's Avatar
SeanR
Went to replace one we thought was busted and it ended up being the ball cup had rusted to the lever on the trans.
Sucked because I now have an extra 3 speed cable.
CJ8 2 928's Avatar
CJ8 2 928
I thought I broke mine but after about 6 hours I fixed it. It came apart at the shift arm. I could do it in 1 hour now.
Old May 24, 2010 | 07:33 PM
hacker-pschorr
Administrator
Should have mentioned this in the OP - this is Todd's read car (see my sig) and he's looking at options to improve on the design.
That is unless this is such a rare occurrence, no reason to bother.
Old May 24, 2010 | 07:38 PM
Landseer's Avatar
Landseer
The lower boot decays and sand and grit can get into the metal sleeve and jam it. That happened on one of the rescue cars. Cable not salvageable.
One other note, the S4 4spd cable is slightly longer than the earlier 4 spd cables, by just a tad, because the S4 TC is a bit bigger diameter.
Old May 24, 2010 | 08:45 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Look underneath the car for an 18" long drilling rig pipe. When I hit one in the road it smashed my shifter cable.
Old May 25, 2010 | 12:48 AM
Don Ashe's Avatar
Don Ashe
Originally Posted by Hacker-Pschorr
How common is this?
Mine was due to cracking on the lower bellows. Once road grit and moisture get in there, it will eventually fail. Has I noticed it and replaced the bellows and relubed the cable, it would have lasted longer.
OTOH, it did last 26 years, so I won't need another until 2036...
-don
Old May 25, 2010 | 12:57 AM
Tony's Avatar
Tony
Ive been shifting mine "manually" since...i dont know when....never an issue! -touch wood-
