No turn signal or emergency flasher
The turn signal and emergency flasher does not work anymore. The dash light goes up when I flip the turn signal. The emergency swithch lights up when I push it down but no flash. Where do I add the blinker fluid?
Could it be # V relay? How do I test it?
I just put in a new relay and check all 4 fuses. Still not working. When I was playing with the emergency switch pulling it out of the pod, I saw some sparks when the switch touch the pod hole. Did I fry something?
Is the emergency flasher switch on the same circuit as the turn signal switch? Could someone unplug their emergency flasher switch and see if the turn signal still works?
Team Owner
disconnect the battery when working on the pod switches they can ground out on the switch openings and let out the electrical smoke
Also, do your brake lights work? (If not, the problem may be in the lamp monitoring module)
Is the cluster complaining about tail light or turn signal bulbs being out?
Yes, the flasher module (V) could be the problem, especially if things are lighting but not flashing. Looks like a pretty Bosch-specific flasher module: it uses a separate connector to feed the turn signal indicator light in the dash. However, you probably could hook in a standard 3-pin flasher module, at least to test: ground to 31, supply to 49, load to 49a. This should flash the turn signals themselves (but not the dash light) if the the problem is the flasher.
I don't see why, exactly, they have a separate output from the flasher module for the dash indicator. I would think it should work with a generic flasher if that pin was connected to 49a, but I'm not positive... maybe it's a lower voltage or something.
Paul
The turn signal does not light up or flash. No light on the emergency switch either.
The brake light works.
No bulb out warning light in the cluster.
I got a 3 pin flasher relay from a local parts store. It is slightly smaller and lighter but plugs in the same spot.
The emergency switch is plugged all the way in.
I got to get this fix before driving 2000 miles on SITM trip!
Team Owner
might be a good time to drop the CE panel and inspect the rear for burned or melted wires if you say you shorted one of the pod switches then thats where to start looking for the problem
Electron Wrangler
jthwan22 - Swapping the stock flasher for an aftermarket version may well work... but I'd strongly suggest not to do it when you are trying to determine whats wrong with your system... its quite pointless - you don't know if would have worked anyway...
Check the fuses by taking them out and testing them with a DMM. Did you remove the pod/steering wheel and combination switch?
Alan
The pod down to the insturment panel was out when I fix the pod crack and put in LED bulbs. I also lost the D light out of PRDN32. I am not too worry about the D light and I didn't get to PRDN32 bulbs with LED because they were burried under another CB. I guess I should go back to see if 2 big plugs and one little white plug are in the combination turn signal switch. I am pretty sure it is plug in.
I hate it when I fix 1 thing and break 2.
I got used emergency switch, turn signal and another flasher relay. I only had to replace the emergency switch and now everything works. Go figure.
