85 to 86 32v Ignition Wire Sets - Alternative??
Basic Sponsor
With the Beru (OEM) set of wires becoming harder and harder to find I have been trying to establish if the 87 to 95 set will fit.
The caps and rotors are the same. The coils are the same as the 87 & 88 cars.
The layout of the wires relative to the cam covers and the front of the engine is the same.
I have measured the difference in the wire lengths and apart from two wires they are the same. On the two that are different the later set is longer so that should not be an issue either.
Anyone know any other differences that I am missing?
Appreciate your help.
Roger
Roger
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Basic Sponsor
I would be very interested in finding a Bosch set.
09265 is not recognised as a valid number but does cross reference to the Beru set. The Beru set sells for about $400. The 87 to 95 Beru set sells for $300 so a big difference.
Colin,
The 87 to 95 set comes with two sets of coil wires to cover both types of coils.
Roger
Colin,
Roger
Administrator - "Tyson"
If your Bosh wires are working out ok that's awesome. I'm never ordering another set from BOSCH and I tried three different times over the past two years to give them "another chance".
The spark plug ends are garbage (compared to the Beru) and the distributor side either the terminals were not properly crimped or not crimpled at all - ON ALL THREE!!!!!
On one set, two terminals were totally missing.
Bosch quality isn't what it use to be.
I've gotten two sets so far and haven't had any issues so far. http://www.amazon.com/Bosch-09265-Pr.../dp/B000BZG4N6
FWIW, Bosch looks like different technology, resistance in wire instead of boots.
Roger, any thought to offering the sparkplug wires with M3 connectors and no ends, and we re-use existing ends?
Basic Sponsor
OK now I know what you are refering to.
There are a number of economy sets available and the Bosch set falls into that catagory.
Nothing wrong with that.
I am looking to supply a direct equivilant with all the spacers and Beru hardware.
When I saw "Made In China" on the spark plug end for Bosch and "Made In German" on the Beru sets........that explained everything.
Lifetime warranty doesn't mean squat when you are on the dyno paying $100 per hour and trace your igniton miss to a defective plug wire(s)
Basic Sponsor
I already offer the wires only - Beru in black or red with the correct male ends so you reuse your existing caps at both ends. $119.
That's the way to go - once you have a good set of plug ends, why toss them out? Just check with an OHM meter to make sure they are within the spec range.
Rog,
I have a local company make them for me.
They are 8mm leads very good quality.
If you would like to start supplying give me a call.
They are non resistor leads FYI availible in red or black.
