928 Forum 1978-1995
Sponsored by: 928 Specialists
locked keys in car
Old 05-07-2010, 10:30 PM
928 user
2nd Gear
928 user's Avatar
Unhappy locked keys in car
I am a new user to this site. I just bought a 928S 1980. I have been working on it all winter long. It now runs and drives. But I did a dumb thing as locking my key inside the car. Any Ideas on how to get in the car. I had a guy try a jimmy stick with no luck. Is there any thing else I can try orther then having a lock smith come out:
Old 05-07-2010, 11:08 PM
linderpat
linderpat's Avatar
Received 2,370 Likes on 1,287 Posts
here is the answer - don't break windows or cut thru the floor. There is a simple tool and you are in and out: http://www.pro-lok.com/p-62-ao17-porsche-928-tool.aspx
or this: http://www.nextgentool.com/store/pro...61575404c78cab
Read this thread: https://rennlist.com/forums/928-foru...in-86-5-a.html
Old 05-07-2010, 11:10 PM
linderpat
linderpat's Avatar
Originally Posted by circlex
Go in through the top right corner of the driver's door with a long metal rod. Push it in all the way to the window switch, then open the window. I tried to use a coat hanger to do this, but it was not long enough -- you need a long metal rod -- I used a rear stabilizer bar off of an ikea cabinet.
You will ruin the door or window if you try this. Plus, if the car is off, the window switch won't work. See the links above.
Old 05-07-2010, 11:19 PM
SeanR
SeanR's Avatar
Ed, thanks for those links, ordering one now.
Old 05-07-2010, 11:25 PM
danglerb
danglerb's Avatar
A017, thats what I bought in my last order to Tooltopia.com. Maybe I should practice with it a bit?
Old 05-07-2010, 11:37 PM
Skiviking
Skiviking's Avatar
Well, I had the same problem 14 days ago....follow the links here and you'll lose less $$$ I unfortunetly had a locksmith come and ruin my weatherstriping along the corner of the door and when all failed he drilled out my hatch lock....and now its $$$ to try and get a replacement....but now I don't feel alone...BEST OF LUCK with getting in...
Old 05-07-2010, 11:50 PM
linderpat
linderpat's Avatar
The old rlist thread linked above should be added to the faq sticky; these cars were designed so as to be very hard to steal.
Old 05-08-2010, 12:03 AM
Hilton
Hilton's Avatar
Per the thread linked above, Bill Ball did it with a bit of an old coathanger.
See this post in particular:
https://rennlist.com/forums/5994064-post25.html
Old 05-08-2010, 03:06 AM
Randy V
Randy V's Avatar
The problem is your relationship with the car.
Per your name - you are a User.
Biotch ain't gonna give it up for you.
Old 05-08-2010, 04:39 AM
StratfordShark
StratfordShark's Avatar
I'd love to try Bill's coathanger trick just out of curiosity. Also good party trick at 928 meets (my last such trick was popping hood from underneath - my release cable broke once and till I fitted replacement I got pretty fast at the hood trick).
Anyway S2 owning friend locked his keys in. He called the shop who normally work on his car, they said to cut and remove the RHS rear quarter seal, and the window just fell out. Cost him a new seal but I was interested in old post from Roger Tyson who claimed replacement glass is cheaper than the seal!
Old 05-08-2010, 05:30 AM
Darklands
Darklands's Avatar
Received 1,154 Likes on 624 Posts
It´s a known problem with the old 928 S. The locks in the doors have a dead point and then you close the doors hard the lock close sometimes from alone over this point.
First rule is every time you´re not at home take the keys out of the car !
The rear quarter window is the easiest way to open the car.
Old 05-08-2010, 04:44 PM
danglerb
danglerb's Avatar
Rear quarter glass is cheapest to replace, but I think I would prefer a new seal to new glass if I didn't already have a new seal. I wonder if some creative muscle, a few big suction cups and lots of soapy water worked around the seal would pop the quarter window out with it and seal both intact?
Main point I get is don't call a locksmith and regardless of what they say let them do as they please. Maybe ask if they have the A017 window vent tool?
Old 05-08-2010, 04:50 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
A replacement quarter glass is much cheaper than a new seal. Quarter galsses are dime a dozen, so they are cheap but the weather stripping isn't but it will make one hell of a mess when you pop one.
Old 05-08-2010, 09:58 PM
linderpat
linderpat's Avatar
Why on earth break anything? Most locksmiths have the tool or something close to it that I posted above. It's simple chaep and quick. Or better yet, just make it yourself out of a coathanger, or buy it.
Old 05-08-2010, 10:25 PM
sweanders
sweanders's Avatar
There is also a rubber plug behind the drivers seat that can be pushed in.
Quick Reply: locked keys in car
