Brought my first 928 home!
Under the Lift
My experience is that reverse bleeding the clutch is the easiest way to get all the air out. Use a pressure bleeder to push fluid into the slave cylinder fitting. This will fill the slave, then the master, pushing the air up into the brake fluid reservoir. Very simple and fast.
+1 on an easy bleed for me, had someone pushing the pedal though.
Great pix! it looks like a really good start! Im very excited for you, had you lived 3000 miles closer Id offer my limited wisdom in person.
-Sam Johnson
78 euro 5spd
87 S4 5 spd
-Sam Johnson
78 euro 5spd
87 S4 5 spd
