928 S4 weird A/C issue
My A/C and ventilation unit appeared to be normal and then suddenly. the vent fan would only come on at highest speed and only with the slider switch in the far right defrost position. I can hear things click if i move it to other positions but nothing changes and the vent fan shuts down. Any ideas?
Looks like the defrost position powers the blower through a relay (VIII?) while otherwise the blower is powered through the resistor set. I'd say maybe a bad resistor set or bad connections to it.
Relay X might also be a possibility.
It shouldn't be a fuse issue, though, since both VIII and X get power through the same fuse (17).
Welcome Pantera! Here's a thread to review: https://rennlist.com/forums/928-foru...operative.html
Post up a new thread on you and your S4!
Rennlist Site Sponsor
Relay, relay, relay...
Swap Relay X, the blower relay, with Relay VII, the defrost relay. If the blower now runs on everything except defrost, get a new 53 relay.
If the resistor pack fails, the blower will normally still run on the top speed.
We have a winner!! THanks to all who replied. It was a flaky relay at the "X" position. You could wiggle it and it would click on and off and along with it the fan. I knew about this but was thinking too much instead of going on knowledge I already had. THanks again for the help.
