First drive impressions - 17x9 ET70 Cup II fronts / 18x10 ET47 Cup II replica rears
#31
Under the Lift
Nice! Those tires already look tight enough to the rear fender w/o additional spacing.
Your front ride height is low already for a street car. Remember, if the tires are larger diameter, then the additonal height (1/2 the additional diameter) needs to be added to the target ride height so you don't change the suspension geometry.
#32
