928 Forum 1978-1995
Sponsored by: 928 Specialists
Eternal Quest For Period Correct Tunes--Tell Me About Roof Antenna
Old 05-02-2010, 07:02 PM
  #31
jmrjames
jmrjames's Avatar
Originally Posted by SQLGuy
External lighting input from the dimmer for the instruments, so that the head unit will dim together with the pod.
Thank you !!!!!!!!!!!
So if it is not hooked up it will make no difference.
Old 05-02-2010, 07:03 PM
  #32
Jim Chambers
Jim Chambers's Avatar
SQLGuy, sent you a PM re: speakers. I connected one of the door speaker plugs to a rear output on the amp and I get good sound up front. That tells me that something is amiss between the amp and the rear speakers, both B pillar speakers and the cargo speaker.
Old 05-02-2010, 08:52 PM
  #33
SQLGuy
SQLGuy's Avatar
Usually, if it's not hooked up, you'll get no backlight on the head unit. If you don't have a handy dimmer or headlight line, the best thing is generally to hook it to ignition 12V.
You might check, though, whether the little lamp in the ashtray is always on, on with headlights, or dimmed. It might make a good source of power for the illumination line.
Old 05-03-2010, 10:31 AM
  #34
VehiGAZ
VehiGAZ's Avatar
Jim - I have replaced my HU and my antenna base on my '89, and still have the same next-to-no reception problem you have. The coax antenna wire is at the top of my list of suspects, but I have not yet that it is really the problem.
I do not want to dismantle the interior to replace it, though! My next diagnostic step will be to set up my old antenna with 12V power and connect it to the HU with some new coax wire (can I use cable TV wire??) to see if that helps. I will be replacing almost all of the sound system components this summer, so fixing the reception problem has to happen with that project.
Good luck!
Old 05-04-2010, 05:27 PM
  #35
jmrjames
jmrjames's Avatar
I wanted to thank you all for your help. I just replaced the defective head unit and it works good. I also applied power to that black antenna wire and the radio reception and quality increased. I would have left it unconnected without the advice here.
Old 05-04-2010, 06:05 PM
  #36
VehiGAZ
VehiGAZ's Avatar
Connect your illumination lead, too! You will get full-backlight on the HU, which will be a very annoying distraction at night. Attach it to any wire that provides instrument panel lighting. I routed mine over to the "upstream" side of the dimmer control with excellent results.
Don't wait - do it while you are in there!
Old 05-04-2010, 10:42 PM
  #37
jmrjames
jmrjames's Avatar
Thank you for keeping me from making a mistake by not hooking that wire up. I am going to use the clock light wire to tap into.
Quick Reply: Eternal Quest For Period Correct Tunes--Tell Me About Roof Antenna
