Interior Light Delay Relay help
#31
Capacitor ?
I was able to fix a few things (the last one was 1986 944 Turbo cruise control brain) by replacing electrolytic capacitors. They frequently go bad with age. There are 2 of them in your relay, they are 1-2 bucks at Radio Shack. Worth a try ?
#32
Electron Wrangler
I dont think they are supposed to come on when the ignition is turned off, AFAIK.
Using Alan's post
Pin - Function
31 - Ground (needed)
31L - To interior lights (needed)
T/TK - Negative trigger from door pin switches (needed)
30a - Power for higher relay functions (optional)
15a - Ignition - truncates delay with ignition on (optional)
31Z - Negative Lock - truncates delay when locking (optional)
I think 15a is to truncate the delay OFF. So when you turn the ignition switch, and the doors are closed the lights go off.
With the delay missing, it could be truncated(guessing here) with either 31Z or 15a. One way to test would be to check 15a for power when you close the door. Then check 31Z for ground with the door closed. If either of these are true the problem is elsewhere.
I hope Alan chimes in to either correct me, or
I am a novice on these cars, but have worked with industrial controls for 20+ years.
Using Alan's post
Pin - Function
The (other post) idea of the capacitor breakdown is also a reasonable thing to check out via replacement - certainly cheap.
Alan
#33
Jumping the relay
Clearly the best solution is to fix the relay.
The next best solution is to jump the relay.
My suggestion is to replace the incandescent bulbs with LEDs if you decide to jump the relay - it will greatly reduce the current via the door and hatch pins.
#34
ok...sorry i am confused, are you guys responding to me?
again i did the bench test on the relay, and when i touch the TK pin with ground I get a click but when i removed the ground i get another click immediately.... no delay, I then tested for continuity from 31 to 31L with the TK pin grounded, and i have no continuity...looks like a bad relay....I also jumped 31 to 31L and the lights do come on.
So it looks as if I had a bad relay correct?
Also, I was trying to test continuity from TK (on CE Panel) to the door bolts to verify the signal(ground) to bring the relay in and I was not getting continuity.....shouldn't I get continuity when i hold a test lead in the TK slot on the CE Panel and touch the bolts on the open doors jam, with the door open, key off? Is that the proper way to check the signal to bring in the delay relay, to check that continuity on the TK slot?
That pin is smaller than a standard 1/4 male blade so I was just kinda pushing the test leads point into the slot where TK is located, pretty sure I was deep enough but i couldn't get continuity. My door chimes do work when the key is on and the doors are open so I feel the push pins are working, but was kinda surprised/ pissed when I was not get continuity from the CE Panel TK slot to the door bolt.
#37
I would ensure both door pins are showing the same (open) continuity to ground.
Connection F15 on the CE should be the connector from the door pins the the CE panel. Check continuity from the connector to ground with door open, should read ~0 ohm doors closed should be Open. Or visa-versa.
Then check the socket on F15 to TK pin slot on socket XXI.
#38
I must ask, how are you bench testing the relay?
I have not tested, or looked at this particular relay/timer, but i would first connect 12v source to pin 31Z and 0v(gnd) to the TK terminal. You should then have continuity between 31 and 31L. Removing gnd you should have a 25-second time delay before 31 and 31L opens. If it happens immediately, i wouldn't lose any sleep over, and call it good.
#39
bench test was as follows: (used a spare 12V battery as source)
POS to 30A
NEG to 31
touched TK with NEG
When I touch TK with NEG i get a click, as soon as I removed NEG from TK i get another click immediately. With NEG clamped to TK, I test continuity from 31 to 31L while TK was grounded with NEG.....no continuity.
Relay smells of burnt electronics, so I am concerned about plugging a new relay into the CE socket until I do some more testing, what testing should I do to ensure I wont burn up the new relay? Again the door chimes work as they should when the doors open and close, which leads me to believe the doors are working, however I will check ohms when I do the testing I am looking for to ensure I wont trash a $160 relay.
What is F15?, I have a 15a on my relay....
POS to 30A
NEG to 31
touched TK with NEG
#40
F15 refers to plug F pin at column 1 row 5
Careful pulling the plugs out of the CE. They can be brittle and break. There is a red tab on the bottom of the CE(behind wires) that unlocks all the plugs at once. You have to shift it left or right to lock/unlock the plugs. After you shift it I think there is an additional tab to get the plug out as well. Look at it carefully before tugging. Or search for illustrations here might help.
#41
Electron Wrangler
Alan
#42
Electron Wrangler
POS to 30A
NEG to 31
touched TK with NEG
POS to 30A
NEG to 31
touched TK with NEG
Re:
You need to make sure 15a is grounded and that 31Z is at battery voltage - so here connect it to 30A. Then test again.
What you smell in the relay may just be quite normal.
Test again - I think you may still find it works OK
Seperately: test for continuity between CE panel: F15 and ground. You should have continuity when either door is open
Alan
#44
holly cow, i will need to buy some new test leads....lol.... I luv buying stuff like that.
so, to be clear the below is my new bench test:
POS to 30A & 31Z
NEG to 31 & 15A
with TK grounded I should have continuity from 31 to 31L.... correct?
POS to 30A & 31Z
NEG to 31 & 15A
#45
Kos-007 is spot on. Before doing anything replace the can capacitors in the relay. This will be the most likely fix. Electrolytics degrade and do not always show leaks or bulging of the can.
I do this for 70s amps and they sound much better when the electrolytics are renewed.
Just make sure you fit the identical values.
