928 Forum 1978-1995
Sponsored by: 928 Specialists
Sorry - Offset question
Old Apr 21, 2010 | 04:57 PM
Rob Roy's Avatar
Rob Roy
On the Bandwagon
Default Sorry - Offset question
18x8 front - 55 offset
18x10 rear - 65 offset
88 S4
Will they work?
Thanks!
Old Apr 21, 2010 | 06:03 PM
Leon Speed's Avatar
Leon Speed
front: yes
rear: is a bit deeper but yes
Ps: depends also on the tires - what sizes are you considering?
Old Apr 21, 2010 | 06:06 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
They will be fine, and you can also use a 21mm spacer in the rear to kick out the wheels/tire to the fenders edges.
If you do go the spacer route, then get bolt on bolt on spacers
S4ordie's Avatar
S4ordie
Not the sharpest tool in the shed
Should work without issues. Tire width has some influence. I'd recommend 245 or 255 up front and 275 or 285 on the rear.
Old Apr 21, 2010 | 06:31 PM
Rob Roy's Avatar
Rob Roy
On the Bandwagon
Thanks!
Old Apr 21, 2010 | 07:14 PM
Bertrand Daoust's Avatar
Bertrand Daoust
Those 2 links might help you:
http://www.google.ca/url?url=http://...kW62CRBg9s35tw
http://www.google.ca/url?url=http://...CoMebZ8KTOq4Ew
Good luck.
Old Apr 21, 2010 | 07:28 PM
Rob Roy's Avatar
Rob Roy
On the Bandwagon
Thanks - I also found a copy of Andy's fitment calculator I had saved many moons ago
Old Apr 21, 2010 | 09:04 PM
Gary Knox's Avatar
Gary Knox
Ken,
You can use 295/30 tires on the rear. They won't touch the inner wheel well walls, and as Aryan and Stan have indicated, moderate spacers will work fine on the rear. You can go as wide as 20mm on the spacers with no problem. 1" is a tad wide, and might require rolling the fender lip. Fronts are fine. I use 255/35's there, with the 295 rears on my '89 and on my GTS.
Gary Knox
Old Apr 21, 2010 | 10:06 PM
blitz928's Avatar
blitz928
+1 on the spacers, exactly what I am running on my '87.
Old Apr 21, 2010 | 10:16 PM
Rob Roy's Avatar
Rob Roy
On the Bandwagon
I do have a set of Ott's rear fender flares sitting in the garage waiting installation, so rears should be fine - have to see what size spacers would work best for those.
I was more worried about the fronts, but sounds like they'll be just fine!
Thanks!
