Pressurized intake after refresh, replaced throttle shaft bearing leaking!
The car is 95% done after my cam cover, intake, clean everything project. Replaced the flappy and throttle bearings and all associated sensors, cam chain guides, rubber, vacuum lines, elbows, silicone intake elbow, oil fill neck.
I built the intake pressure tester and put 2.5 PSI in it. I can hear a leak(s) and narrowed one down to the throttle shaft on the drivers side. The bearing seal must have been damaged upon replacement!
Takes 10 seconds to leak down from 2.5 PSI.
Wish I had a smoke tester to see if I have any other leaks.
I may also try soapy water around the MAF and elbow to check for leaks, some folks have had issues getting the silicone elbow to seal.
Can't say I'm pleased as this was a lot of work to get to this point. At least the fuel lines will come apart easy!
Sometimes it's better not to know.![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Do I take it all back apart or drive it?![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Any thoughts?
Any thoughts?
Captain Obvious
Super User
Super User
The throttle shaft doesn't have to seal perfectly. Considering the amout of air the engine uses, that tiny leak is insignificant.
Team Owner
did you use the double sealed shaft bearings?? Roger sells them
Craic Head
I had a leak at the oil dipstick and also at the oil filler cap (both have O-rings to replace and could cause pressure check leaks during a pressure test).
For next time (or anyone else), you can test the throttle assembly on the bench before reassembly:
![](http://forums.rennlist.com/upload/throttleairguidetest.jpg)
Mike,
S4 is a different but could be done . Wish I did it now!
Not sure if any of the local shops would have a smoke tester and if they would let me rent it no less! Shure would be nice, could test both cars.
Thanks for all the help. Still not sure if it is worth taking all apart again.
I know what Dwayne would do!
Rest in Peace
Mike,
