need pointer to take apart kickpad (under steering)
I'm removing some PO wiring (ug) and need a tip on disassembling the lower pad undere the steering wheel pod.
I can only see the 5mm hex bolt right in the middle between the steering wheel pod and the kneepad.
Can someone provide a hint on where the other fasteners are?
It's a 94.
It's a 94.
Team Owner
IIRC you have to remove the side vent duct housing to reveal the 10mm nut on the end of the dash
then there are 2 13 mm bolts on the console
then a 10mm bolt under the steering column
