How do I change the manual transmission fluid & differential?
Me again, the slowly learning 928 owner. I'm going to change my manual transmission fluid and was advised to change the differential fluid as well. Is there a write up anywhere on how to do these basic jobs? Hell, I don't even know where to fill these fluids!
Thanks guys for putting up with my ignorance to some of the most basic jobs.
I appreciate the help.
I just changed my diff fluid the other day. It's easy.
You've got a drain plug, and a fill plug.
Open the fill plug first just to make sure you actually can. If you open the drain plug first, let all the old fluid run out, then find you cannot open the fill plug, you're screwed.
Once the fill plug is out, open the drain plug and drain out the old fluid. Then reinstall plug.
Then use the fluid pump you can buy at any parts house to pump in the new fluid into the fill hole until it just begins to run out. When it starts to run out the hole as you pump it in, you know it's full. Reinstall plug. You're done. Enjoy.
Manual tranny's are the same.
I installed Amsoil gear oil along with a healthy dose of Lucas Oil Stabilizer and a healthy dose of Tufoil oil additive. This three-way is a magical combination that equates to removing 300 lbs from your trunk. It's awesome. Do the same in your gear box. Unless your gear box and diff are one and the same unit. I have an auto.
If you install Tufoil in your manual tranny, your shifter will turn into silk. Nothing more smooth.
By the way, you'll need a 17 mm hex-head to fit into the plugs. Like a big Allen wrench. You can buy them anywhere. A socket-style to fit onto your 1/2" drive ratchet works best and takes up less space in your tool box. You may need a long breaker bar to get the plugs loose.
Archive Gatekeeper
On early cars there are 3 plugs to deal with, 2 drain plugs on the front and rear of the tranny/diff, and 1 fill plug on the rear. You need a 17mm hex socket. THE FIRST PLUG TO UNDO IS THE FILL PLUG, half way up the rear diff cover. You'll be sad if you drain the trans and then can't get the fill plug out...
Here's the rear drain (lower) and fill plugs (upper) on a GT box (which have the 10mm hex plugs, not 17)
Filling can be done either by snaking a hose from above (thru the battery box?) or pumped up from below like so:
16 ft lbs torque on the drain/fill plugs, add ~4 quarts of 75W90 GL5 gear oil. Brand is your choice, this ain't politics and religion.
Thanks guys.
Its always nice to have another spot to run the filler hose so that you can use gravity. The race car makes this easy as I use a plugged hole above the transmission and just hang a funnel from rear hatch.
I used Tony's page as a reference for my transmission and differential change.
http://members.rennlist.com/v1uhoh/
FWIW - My differential didn't leak until I used synthetic fluid ... Just say'n.
Good luck and hope to see you at a future 928 GTG! / Bruce
On all manual gearboxes there are two drain plugs, one at front and another at rear plate below fill plug. It is important that both drains are opened. If not, all old oil will not come out unless car is in serious angle.
Archive Gatekeeper
Sounds like the old-school problem of switching to synthetic: oil molecules are very small, and easily slip past older seals.
