928 Forum 1978-1995
Sponsored by: 928 Specialists
WUR
Old Apr 10, 2010 | 12:07 PM
Want to be's Avatar
Want to be
Default WUR
Question, which 928 5.0 liter models have a WUR?
Also, how difficult is it to find a new unit when needed? I ask, because i have never found a rebuilt unit that worked for a 911.
I have been considering an earlier year 928, but has some concern about the WUR.
Thanks jpc
Old Apr 10, 2010 | 02:20 PM
tailpipe's Avatar
tailpipe
i don't think any 5.0 cars have a wur they were only used on euro CIS cars untill 1983 after that all fuel injecton becomes electronic 928 int will rebuild any wur you send them
Old Apr 10, 2010 | 02:50 PM
Want to be's Avatar
Want to be
there was a 5 liter on ebay, an 1986, the owner said he thought it needed a new warm up regulator. I assume he was correct.
jpc
Old Apr 10, 2010 | 03:02 PM
SQLGuy's Avatar
SQLGuy
I'd assume he's wrong, unless he bored or stroked a 16V to 5.0L, or retrofitted CIS on a later engine.
Warm up enrichment on the LH engines is through extra fuel through the regular injectors. The temp sensors and the CPS are used to regulate idle and mixture, with the LH box doing most of the work. Problems are usually due to vacuum leaks or a bad or sticky idle stabilizer (bolts to the side of the throttle body).
GlenL's Avatar
GlenL
Post a link.
Tailpipe is correct: no 5l had a WUR.
Old Apr 10, 2010 | 05:12 PM
tailpipe's Avatar
tailpipe
I think he might be mistaken and is thinking about an auxilary air valve (AAV) I think all the 928s have one in some form thats prolly what he ment and again I think they are all rebildable from our vendors here at a resonable cost
Old Apr 10, 2010 | 07:57 PM
Want to be's Avatar
Want to be
http://cgi.ebay.com/ebaymotors/Porsc...item230659a7ae
Engine size is wrong as-well. He says he is a collector, but does not know what his engine size is.....
Old Apr 10, 2010 | 08:16 PM
rixter's Avatar
rixter
928 OB-Wan
on the plus side, has lsd and heated seats... doesn't look half bad, w/ recent tb/wp could be a nice project for $5800
