Dash Lights & Instrument Cluster Lights Out - Worked 5 Days ago
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Could be the interior light relay too. I believe they are on the same circuit, but different terminal (or pins) on the board.
The lights do work on the interior... Seems like I have seen this before, but a replacment rheostat fixed it before... But then connecting the wires should do it too..
The dash light are on all the times
Does anyone know how this wiring circuit is configured? Could the problem be at the headlight switch? Or can the pod portion be pulled so that it stays to ground and on all the time nd the remaining lights would power up once the lights are on?
Am I correct that the cluster is grounded to complete the circuit to power up?
There has been some interesting wiring on this car over time. I have fixed (back to factory) on everything less this issue.
