Dash Lights & Instrument Cluster Lights Out - Worked 5 Days ago
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I checked Fuse 44 on the CE Panel and it's fine. The ashtray light illuminates and the LED for Parking Lights turns on. However, there are no dash lights or instrument cluster lights illuminating. 6 days ago everything was functioning. I know this car hates sitting, but what else on that circuit would cause inoperable lights?
Team Owner
check the rheostat under the dash on the left side of the steering column
Sounds like you have a break in the wire that makes up the rheostat... the wiper is only making contact at "full bright" (where it hits the 12V supply end of the wire). Easiest thing would be to replace it.
Mine was like that when I bought the car. Rheostat was more or less melted and PO had disconnected it. Just created an s/c and now have full brightness all the time.
Anyone knows where to get a new and how much? According to PET they aren't available from Porsche.
Fuse 24 Assassin
Fuse 24 Assassin
I usually like dash lights bright. I may just bridge it. I have new bulbs in there anyways and I like how bright they are.
Since you mention MY 90 I assume it's meant for me and not the original question in this thread. -90 onwards is 928 613 031 00 which gets "Part number 92861303100 not in stamm". But thanks anyway
Ah ! OK, so something changed with the introduction of digi-dash ? "part number unknown".
The rheostat for the later cars also comes up with unknown as well...
Have you enquired at a Porsche Centtre ?
Old thread additional question.
On an 89 I am working on, I can get the cluster to go full bright all the time (headlights on or off) when I pull or blow fuse 44. When the fuse is good, I can use the rheostat or bridge the wires and the other lights work, but not the cluster... The cluster will be out with lights on or off.
Any thoughts?
Any thoughts?
Fuse 24 Assassin
Fuse 24 Assassin
By any chance, are you getting good connections to the circuit foil? I pulled my cluster one more time to replace a burned out bulb, but upon re-installation, I couldn't get the lights to illuminate. I then removed the cluster again and 'reconnected' everything only to successfully have every bulb light up again.
I did short the lines to ground and that blew the fuse, but illuminated the cluster...
Could I be grounded in the cluster somewhere and thereby only having a ground illumination of the cluster?
