The 100bar pumps from GTS (I think MY90+?) are different inside to the earlier 75 bar pumps.
That seal kit fits the 75 bar pumps (which my '89 has).
I bought a PS pump from an '86 to rebuild on the bench to do a swap for my 89's noisy one, but it turned out the '86 car had been given an upgrade to the later pump.
I ran into the same issue. Ended up replacing a few generic o-rings, but had to leave the shaft seal(s). Thankfully it's not leaking. Please update us if you get all the seals/rings to rebuild it.
Why are you rebuilding it?
Was it leaking? not producing pressure?
Colin,
No. Just WYAIT. I've been replacing rubber items as I get the chance, since they seem to have deteriorated on this car. In this, case it turns out the shaft seal looks pretty rough.
