What KIND of welding is needed for Aluminum?
#31
if you were closer i would offer i'm cheap just bring some beer or a bottle would weld them up np offer is always open if anyone close needs some tig done
#32
Chronic Tool Dropper
Dean--
How did you do on this? Pics make it worth more, in case you forgot...
#34
Just so we don't confuse the OP, don't use Stainless wire on the aluminum front fenders.. stainless and aluminum typically will only weld together with HIGH explosives.. ever seen Explosion Welding.. COOL STUFF!
Watch this!!
http://www.youtube.com/watch?v=ldl6f...layer_embedded
Watch this!!
Very interesting
#35
Had it done at a local weld shop. I pushed the edge of the hole IN so that when it was welded I could grind down without grinding the weld plug loose...You just about cant tell where the holes were even before primer.
#36
Location: Seattle - it's not Hell, but you can see it from here!
Watch this!!
Watch this!!
#37
i have been thinking about leading the wholes in my car. funny thing is, i am taking the welding courses at my local com college, but i have not gotten to tig yet. but being a beginner and this being a DD car, i dont want to strip it down, or mess it up. but i have time to think about it. anyone here lead before?
#38
This is very useful information:
http://aluminumintransportation.org/...ads/reppub.pdf
Independent of whether it is aluminium or steel; welding of thin metal is not for beginners. As others have pointed out, the methods need to be know, proper equipment is needed and quite a lot of practice is also needed on scrap metal pieces.
#39
It is possible to solder aluminium. I always see it at car shows and untill recently, I didn't believe in it. I bought a DIY kit however and last weekend I tried it out. The aluminium part was so big, I had to heat it on the kitchen stove, helped by a propane burner. And still, I didn't succeed.
You can see however that it works: http://www.youtube.com/watch?v=OLvDHwQFvAM
And read some more info here: http://www.aws.org/wj/2004/02/046/
After a lot of questioning to the seller at the market, he let go of the biggest secret: The wire you buy probably is just a little aluminium, and a lot of zinc which has a lower melting point than aluminium.
#41
My favorite welding trick is to back the hole with a copper plate on thin gauge metal. The alu won't stick to the copper, and the copper eats the heat and keeps the panel from warping. As I've said before, the copper also prevents hole-blowing. Best trick I ever learned. Bronze works as well if you can't get copper.
#42
Man of many SIGs
![](http://www.matcotools.com/ProductImages/pp23.jpg)
#43
Former Vendor
Copper,brass,bronze for backing aluminum.And you can use aluminum as a backer when welding steel and stainless steel.Aluminum sucks the heat right out of the parts and prevents warping. Ed
