Plugged Up?
The drain plug pictured below is from a '90 GT g.box/diff. Oil is slighly dirty and sures stinks.
Is the metallic residue on the magnet typical?
I got away with baking brake rotors in the oven earlier this will be a total different matter. May have to wait for the next hair/massage appt.
Can you imagine the mess if the plastic bottle explodes?
I used to boil m/cycle chains in oil long before O-ring chains became the norm.
The smell remains with me to this day after +30yrs..............I'll go buy the pump.
I was thinking about ways to heat the diff fluid since I plan on the job in a couple weeks. The double boiler method came to mind. I'm a little afraid of trying the microwave.
I was going to try the "Set in the Florida sun on a piece of Aluminum Foil for an hour " Method. Do you think it will suffice? Or not hot enough?
I'll be using Brad Penn 75w90 Hypoid and I have a quart hand pump.
