Does anyone know what this part# is?
I have lost all oil from it. The part# 928 116 411 6R.
I am 928 ignorant obviously, so any help would be appreciated.
Thanks.
Thanks.
Doesn't look like it.
The drive was great. I went to move the car after I got it home after being parked for 20 minutes or so and there was a pretty big puddle of oil coming from part# 9281164116R and it wouldn't start.
I then checked the oil and I was bone dry?
Any suggestions?
It's coming from here, looks like this:
Any suggestions?
I'll guess rear main seal losing oil into the clutch area? The hole looks like the inspection point for the clutch.
Could also be somehow the clutch slave cylinder as this is right there? I know this wouldn't explain the empty oil from motor but it could be a multi disaster.
Tim
Tim
Rennlist Sponsor
Starter wouldn't "turn over, or engine wouldn't fire up?
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Rennlist Sponsor
True, obvious rear main seal blown out, but if the "won't start" means "starter won't tuirn over" all of the oil could have just fouled the starter (or of course worse).
It wouldn't turn over. It did start earlier and I drove her in the garage.
I'm going to get oil now. Mobil 1 15W-50.
Thanks.
If it's the rear main seal, what will that set me back?
Thanks.
Rennlist Sponsor
About 8 hours of work,
$30 for special tools, (M12 triple square iirc)
and about $40 for the new rear main.
If it did blow out make sure that the crankcase breather is not plugged!
and if your clutch discs got soaked in oil, they will need to be replaced.
Rennlist Sponsor
Depending on the answer to the next question..., or if it was only the starter that fouled and not the bearings seizing and then cooled off :-(
Yes, inquiring minds want to know...... and did you notice any oil pressure drops or warning lights before you stopped driving it (and saw the oil and it wouldn't turn over).
Thanks guys.
