Keel Twinscrew Alternator Belt Length
I'd like to start a repository of parts information related to Andy Keel Twin Screw Supercharger kits.
I just replaced the supercharger belt with a Goodyear Gatorback 4060445 belt. The 60445 deciphered means it's six ribs by 44.5 inches.
Anyone have the dimensions of the alternator belt? Mine just broke, on the highway, and took out my fan harness with it. Bummer; however, I had enough battery power to make it home from 30 or 40 miles away, so it could've been worse.
Except now, I don't have an old belt to use for reference...
Thanks in advance, and maybe we could post other belt sizes germane to the Keel Twinscrew Kits? I tried to search but couldn't find references to Keel and Alternator that listed belt sized.
Oh, and one more thing: The power steering belt I recently changed was a Napa 040413. 4 ribs, 41.3 inches. It just barely fit, you might want to go a bit longer.
Last edited by bd0nalds0n; 03-31-2010 at 11:22 PM. Reason: Might not have been clear I need immediate help re: a question
Under the Lift
Hi Brian:
The Keel setup uses the stock alternator belt, as Darien shows.
For the PS, Andy listed a Dayco 5040420, which is 42" 4 rib, just a bit longer than the Napa belt you used, which would be equivalent to a Dayco 5040413.
I will look for the airpump belt, i just took mine off. (Smogged last month) Actually I cut it off as i didnt want to deal with the PS and Alt belts again.
Thanks for the reminder and help.
