Shifter not working
I parked at Walmart for like 20 minutes to get my hair cut came out and now my shifter is stuck in second and i can move the shift lever around like jello where all the gears are suppose to be any suggestions?
Your front shifter ball/cup is broken and come loose. BTDT, drive it home in 2nd, order the parts and change it out. When the new one is installed, most guys put a large tie-wrap over the shifter rod and the torque tube to prevent it from falling off again as the new one wears.
You can also try re-installing it on the existing ball and do the tie-wrap trick now. Sometimes it will hold together for a long time, allowing you to defer the repair to a more convient time.
Craic Head
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I know, this one went right down the tubes. Surprise ending, though, that was worth something.
Oh, and I want to go to New Zealand. I mean Tasmania.
http://s844.photobucket.com/albums/a...Photo-0043.jpg
http://s844.photobucket.com/albums/a...Photo-0044.jpg
This is what i saw is this what you were talkin about the pekcab?
If not does anyone know what this is, it looks like the lever holds it and it broke off
Actually PEBCAK stands for Problem Exists Between Chair And Keyboard.
This is a 928 forum. We have no idea about your car.
I recommend you contact a Capri forum board from this point forward.
yes this is a 928 form oh well im sure shifters have stuff in common and im sure the pics i posted some one will recognize so i dont see a big deal with me posting what i did
