bonding agent to attach hood crest to plenum
I used 3M Plastic Emblem & Trim Adhesive. You can buy it at autozone, napa, carquest for under $5. It will bond to vinyl, plastic, and metal..... resistant to water, heat, fuel. On the down side it takes 24hrs to bond.
Poseur
Team Owner
FWIW the pins on the rear of the badge are soldered on so a hot soldering iron will remove them, no grinding needed
if I sifted the replies correctly:
3M adhesive 2
RTV adhesive 4
JB weld 2
metal epxoy 1
so many options. I think I'll try the RTV.
thanks for the replies.
3M adhesive 2
RTV adhesive 4
JB weld 2
metal epxoy 1
