I have exhausted all efforts still NO START... FIXED!!!
#92
No real updates except I swapped out and tested the ECU and the L-jet with some spares Hacker was kind enough to send. Changed nothing still have the problem.
Here is the updated list:
New igntion switch
New fuel pump
New fuel filter
New ignition relay
New fuel pump relay
New temp II sensor
New thermo time switch
New cold start injector
Cleaned ground (block to frame)
Cleaned ground (battery to frame)
cleaned ground (behind CE panel)
New starter
New battery
cleaned replaced all fuses
Cleaned AFM (springs fine working normal) resistance test was fine
Used Auxiliary air valve resistance test was fine
swapped out and tested ECU with spare
swapped out and tested L-jet with spare
anything else left to test?
New igntion switch
New fuel pump
New fuel filter
New ignition relay
New fuel pump relay
New temp II sensor
New starter
New battery
#95
Chronic Tool Dropper
Put the voltmeter on coil terminal 15 and see if there's power there with the key in the run position.
#96
These are crucial:
The ground under the car, passenger side, a cable connecting block and frame.
Another (might be split into 2) under the passenger side cam cover that grounds ignition harness components and I think that includes brain, to the block. It stems from the injector harness near the passenger side firewall.
Then there are four more. Not sure if they can contribute to a no start.
Under pod, seen looking up while laying on your back with head on the brake pedal. Front left of radiator. Front right of radiator. Behind passenger quarter panel near taillight.
The grounds can even show continuity across them, but not be clean enough to allow passage of enough current. If loose or corroded, they can contribute to intermittant behaviors as you hit bumps or draw more or less current through the subsystems.
#97
Cause of that primary resitor failing can be careless/accidental connection of the battery lead and the aux contact wire on the starter solenoid, or dying ignition switch when 15 contact no longer works. Or just old age. The problem persists after ignition switch replacement.
#99
Just a thought...I replaced an old ignition switch with a new one that was bad. I kept discounting it as an issue because it was new. Swapped in another new one and all was well. Your windows not working 50% of the time could be a sign.
#101
Administrator - "Tyson"
Same location as the ignition brains, just the opposite side.
During some troubleshooting a few years ago I simply attached a jumper over each resistor. Drove around this way for a few days.
Maybe I missed this, but have you tried a different coil?
#104
Chewy
http://members.rennlist.com/sharkski...leShooting.htm
Dave's write up is great...I would follow it step by step...
On the recently dead 84 Lemons racer....the no start is the resistors.....I checked the resistance and one is about 4x as high as it should be..... that and the coil is reading a bit odd too.... Resistors are $56 for both and a new coil is only $68...I would change them all at once
#105
Update!!!!!!! Grounds grounds grounds!!!!! Landseer I owe you a beer if we ever meet. I didn't realize the aluminum fuel rails I had bought from Tony came with injector hold down brackets that were painted. Cleaned up the two injector grounds mounted them to the old smog pump bracket mounts in the cam box and she fired right up! I can't thank everyone enough for the support and troubleshooting. Just in time for spring. Ground must have been enough to run for a month or so then crapped out.
