928 custon steering rack
Hi, i have a doubt...
someone change the stock steering rack for other with electrical function?renault clio,twingo, vauxall corsa...
i would like to change the stock steering rack for a electrical but my headers are at close than the steering crosshead and dont know who can serve me.
thanks for the help
thanks for the help
Administrator - "Tyson"
Here is a kit offered for the replica Cobra crowd that uses a Toyota MR2 power steering pump:
http://www.fastfreddiesfabrications....p?id_product=4
These pumps are easily found for $100 or so in the states in junkyards, no reason why it wouldn't work for a 928.
Rest in Peace
There may or not be a revised power steering rack in the works.
Would be nice to get a bit more power assist, maybe even speed sensitive.
I may just be dreaming though.
I have a MR2 setup here that I am planning on installing on my Audi if you need any info from it. When I was looking at modifying my Audi setup, the MR2 pump seemed to be the most reliable option.
It has a simple "PLC" that modulates pump voltage dependent on speed, and has activation switches attached to a cam on the steering wheel. If the steering wheel was turned and bumped the micro-switch, then it would activate the pump, voltage going to the pump was determined by wheel speed. So, the pump never runs when the wheel is relatively strait. I was going to modify the system: keeping the activations switch idea, but install a 30amp PWM controller to adjust the pump speed, giving me complete control of the amount of assist. I never really thought about adapting it on the 928 because I always liked the steering.
Hans
Hans
The Parts Whisperer
Here is a quick little "how to" using the Toyota pump. Looks like it can be configured a few different ways based on speed input and steering. It can be set to shut down when traveling in a straight line
http://www.evalbum.com/tech/mr2_powersteering.html
