identify this plug?
identify this plug?
anyone know what this plug is for and where it should be connected? i noticed it hanging behind the snap-on cover in passenger footwell-its coming from the passenger door but i looked around and couldn't determine where it should be connected. thanks!
To assist us to help you, what year model and type, S4 GT or GTS car do you have and what type auto or manual.
In addition in the electrical drawing for the 928, there is a plug/connector chart and and schematic of the car with the location of the plug/connector.
I you are going to DIY on the car would highly recommend that you get Jim Moorehouse's Technical CDs as they include all the information you will need and more. You can buy them direct from Jim Moorehouse or from Roger at 928Rus.
Tails 1990 928S4 Auto
Tails
Tails
You will have one just like it on the drivers side by the 18 pin connector too.
Tails
Tails
From that picture I can tellyou for certain that your car did come with a factory alarm, and that the portion of your key which goes into the lock will be roughly 1.5" long. This idicates a factory alarm.
The cars without a factory alarm had none of the wiring in the car as it was a completely seperate harness.
I have checked the electrical drawings for the 88S4 and it appears to be Terminal 40 located at 7cl on the 928 location sketch.
If this is correct it is for the Alarm system/door lock and the receptical for terminal T40 is located above the EZK/LH Contorl units.
Check the color of the wires going to the pins of the plug in your photograph to confirm that this is in fact the correct terminal T40.
If it is T40 the wires should be as follows:
Pin 1 BR/RD - Brown wire with a red stripe
Pin 2 BR - Brown
Pin 3 BR/GR - Brown with green stripe
If they are not these colors then please advise the colors and I will try and locate the terminal via the colors.
Pin 2 BR - Brown
Thanks for your help, Tails - and everyone else who chimed in...mystery solved
