The Good, The Amazing, and The Ugly - RUF V8 Engine
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
The Good:
See for yourself. It's powerful as hell too!
The Amazing:
It will be used in a Porsche, but not labeled by Porsche
The Ugly:
Many 911 Purists will be pissed off because it's going in a 911. HA HA! This should've happened a long time ago!![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The Amazing:
The Ugly:
New RUF eight cylinder powerplant for the RGT-8
RUF is proud to present the brand new RGT-8 at the Geneva Motor Show, 04th -14th March 2010. This spectacular prototype vehicle is powered by a completely new RUF designed V8 engine with a 180° crankshaft “Flatcrank”. Four valves arranged spherically together with multipoint fuel injection ensure optimal mixture conditions while the dry-sump system supplies the necessary lubrication. The lightweight engine has a very compact design, has a capacity of 4.5 litres arranged as a V8 and delivers 404kW (550bhp)
@ 8500rpm and complements with a maximum torque of 500Nm
@ 5400rpm. At all stages of the design process, compactness and weight saving were of priority, the result of which is a total engine weight of less than 200kg. A 6 speed gearbox with shortened gear shift movement transfers the power to the rear axle. To ensure the best adhesion characteristics, the RGT-8 is supplied with
Michelin Pilot Sport Cup tires running on 19 inch RUF forged alloy wheels utilising a single central retaining nut.
The powertrain is rounded off with sturdy ceramic brakes as standard for optimal braking.
The current Porsche 911 forms the basis for the RGT-8 chassis which is then further optimised with bodywork components from RUF. As always, an integrated roll-cage is supplied delivering increased chassis stability and passive safety. In addition, we are pleased to offer a Frère package which enhances the standard vehicle with special front fenders, nose and dashboard components. The styling was inspired by the 550 Coupé with which Paul Frère, the Belgian race driver, won the best of class at the 24 Hours of Le Mans in 1953.
The RUF RGT-8 production start is planned for 2011.
Fleet of Foot
So where's the ugy part.....
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
i wonder if this is similar to the RS spyder engine that Porsche just put into their hybrid Porsche 918 Spyder, only rebadged as a RUF.
That engine design is pure race car, thats not in anyway a production engine. (Although it sounds like they will mass produce it)
Actually that engine should have been put into a boxster or cayman, why they put it in a 911, I have no idea!
I think they get over $100,000 for their 6cylinder twin turbo 650 engine....RUF is never shy about charging ! their tubo exhaust is about $8,000 just exhaust no turbos !
Rennlist Site Sponsor
Just as a comparison, this small block Ford pushrod engine weighs almost exactly the same (440 pounds) with aluminum heads. For extra money, you can get an aluminum block that is just a little lighter. The "kit price" is for the stroker kit to install into your engine.
Not quite the "bling factor", is it?
317ci
Ford Performance Solutions
1004 Orangefair Lane
Anaheim, CA 92801
714/773-9027 • 714/773-4178 FAX
www.f-p-s.com
Bore: 4.060”
Stroke: 3.100”
Crankshaft: Nodular Iron 302
Rod Type: Eagle H-Beam
Rod Length: 5.400”
Rod Ratio: 1.74:1
Pistons: Ross Ultra-Lite
Rings: Childs & Albert
Bearings: Clevite 77
Max. RPM: 8,000
Maxx. HP: 650
Approx. Price: $1,700.00
Comments: This kit provides a solid foundation on which to build. You can grow into this kit with big
horsepower adders. Very similar to the Coast High Performance kit just mentioned.
317ci
Anaheim, CA 92801
www.f-p-s.com
Bore: 4.060”
Stroke: 3.100”
Rod Length: 5.400”
Rod Ratio: 1.74:1
Max. RPM: 8,000
Maxx. HP: 650
Man of many SIGs
I cannot begin to imagine the problems that a newly designed engine would have. I wouldn't want to help them work out the bugs. Not that I could ever afford that engine anyway.
Fuse 24 Assassin
Fuse 24 Assassin
Hey if someone can afford it, they can afford to work out the problems.
I haven't heard of any issues internally with RUF engines, but then again if the company isn't as mainstream as Porsche, their problems aren't really out there to 'google.'
