Rigid Brake Lines
Basic Site Sponsor
Basic Site Sponsor
Being both in the high performance hose business and the Porsche business makes this one easy.
Mastercool makes the best flaring tool that I've ever seen or tried. Snap-on sells them for 2X what you can buy one directly.
It's hydraulic and worth every penny. It does stainless line like it is made from butter.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Re. stainless steel pipes. I was led to believe that stainless steel
pipes were a bad idea for the very reason mentioned, that they work harden.
The sort of vibration that you get on cars causes the stainless steel to harden
then ultimately fail. The same is true for plain copper pipes.
The virtue of Cunifer is that besides being corrosion resistant, it doesn't work harden.
Its main disadvantage is that it is harder than plain copper so is more difficult to bend
and to form flares in.
